搜索 | 用户支持
详细了解
verification words do not come up when replying/finalising a post ?
  • 1 个回答
  • 3 人有此问题
  • 10 次查看
  • 最后回复者为 cor-el
When replying to a free personal add on Craigs List the verification words do not come up &when finalising a post on Craigs List the verification words do not come up...???
所有回复 (1)
See:
Start Firefox in Diagnose Firefox issues using Troubleshoot Mode to check if one of the extensions is causing the problem (switch to the DEFAULT theme: Firefox (Tools) > Add-ons > Appearance/Themes).
  • Check the permissions for the domain in the current tab in "Tools > Page Info > Permissions"
  • Check that images are enabled: Tools > Options > Content: [X] Load images automatically
  • Check the exceptions in "Tools > Options > Content: Load Images > Exceptions"
  • Check the "Tools > Page Info > Media" tab for blocked images (scroll through all the images with the cursor Down key).
If an image in the list is grayed and there is a check-mark in the box "Block Images from..." then remove that mark to unblock the images from that domain.
There are also extensions (Tools > Add-ons > Extensions) and security software (firewall, anti-virus) that can block images.
